- Sep 9, 2007
- fenton mi
- Automatic
what is the easiest axle to do a sas with. the truck is a dd and will not have over 33's on it
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Then what is the point of a SAS?
I'm guessing by his screen name that his truck is 2wd. Hence the necessity of the SAS.
But then again I'm just assuming.
no the truck is 4x4 the only 2wd truck i have is a 66 ford f-100 with a big block
maybe just maybe the front ttb is bent or even broken and i want to up grade incase i bo go with 35 did you think of that?
As for which solid axle, well if its not going to see larger than 33's, I would say that an high pinion D30 out of an XJ should work fine, otherwise a D44 out of an early bronco is the next easiest swap.
Good luck!
