Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
Still not able to keep the truck running...removed and resealed the carb gaskets and checked for any vac leaks that I might have missed...
The truck did run a bit better but won't stay running once I open the choke...so...as someone had mentioned this and I didn't suspect it, the fuel pump...
Can a pump that is not maintaining the 5.5 - 9 PSI cause this to happen?
I did notice that the last time I drained the tank the gas was coming out in a trickle as opposed to a stream...and it almost seems like once I open the choke the engine is starved for gas...if I press the accelerator on the carb it will rev up (meaning it is getting gas flow) but dies as soon as I stop moving the accelerator...
TIA
TIA
