- Aug 9, 2007
- Age
- 41
- auburn/minot maine
- Manual
will the sable dohc swap into a ranger....will that bolt up to a 3.0 tranny?...and what tre the horses on them
I do know that the front wheel drive vulcan and duratec share the same transmission.
Vulcan V6 pattern
2.3/2.5L HSC FWD I4
3.0L Vulcan V6 (FWD and RWD)
3.0/3.2L SHO V6
3.8L Canadian Essex 90° V6 (FWD only)
Duratec pattern
2.5/3.0/3.5L Duratec V6
3.4 DOHC SHO V8
http://en.wikipedia.org/wiki/List_of_Ford_bellhousing_patterns
Whether it's enough just to slightly justify it's own pattern, or it it's just completely different, within 10 minutes of researching, I couldn't find an answer to that.
Pete
Edit: Yay! My Tempo has a 3.0L bolt pattern. I couldn't imagine that little car w/ a 3.0L.
a lot of vulcan v6 tempos were also AWD![]()
just because the same transmission was used behind the 2 engines doesnt mean they share a bellhousing bolt pattern. the same way the M5OD was used behind the 2.3, 4.0, and 3.0...but none of those motors use similar bolt patterns.
thats why i made that template, i got tired of finding bits of information on the subject but no solid answer one way or the other.
true, I had the same problem, never could get a streight answer, and didn't know if i should trust wikipedia or not. So I decieded against the dohc swap.
but when all is said and done...the SHO 3.0 would be slightly less work (it DOES bolt to the stock vulcan trans.), more power (20 hp more), same mileage, infinitely more "modable", and just as unique....its up to you.
