mwake83
- Dec 21, 2007
I have an 88 Ranger with a 2.9l. The engine recently started running rough intermittently at idle and while accelerating. It will do this for about 15 seconds and then usually run fine for a few minutes. It feels like the engine is not getting enough fuel and the engine rpms drop to about 400 then bounce back up. Runs like this when cold and warm. Checked fuel pressure, it is at 30psi while running, jumps to 38psi when sputtering. Pulled codes 22 and 43. No smoke out of exhaust. I have replaced fuel filter and pump, 02 sensor, map sensor, tps, tfi, and engine coolant sensor. Checked for vacuum leaks and have not found any. Any suggestions would be much appreciated. Thanks.
