- Sep 3, 2008
- Manual
I love my truck, but if I can't work this out soon my wife wants me to sell it so I'm hoping someone here has some insight. The truck is a 1994 Mazda B4000 with a manual transmission.
I just completed swapping in a used engine to replace mine that had either a cracked head or block. (Long story there.) The engine came from a 1994 Explorer. It's a V6 4.0L w/EGR.
Since I put it back together, it shows the following symptoms:
- Runs *perfect* and smooth for the first 60 seconds after starting it.
- After 60 seconds, horrible hesitation, loss of power. Engine sounds like it's running underwater almost.
- A quick depression of the accelerator all the way down clears up the hesitation, but it returns 30-60 seconds later, even if I'm just maintaining speed.
- If I'm driving in 4th or 5th gear and it starts to 'bog down' a release of the accelerator, and then slightly depressing it to maintain velocity clears up the hesitation.
- Check engine light comes on and off. Stays on for around 2 minutes, then off for 10 minutes.
- Hooked it up and the code reader didn't report any codes. Also passed all tests.
- While running while hooked up to code system, O2 sensor readings don't adjust during acceleration. Constantly show same reading "0.98" (I don't know what that means, though).
This is what I've done so far:
- Checked all vacuum lines. They appear fine.
- Replaced both O2 sensors
- Replaced throttle position sensor
- Replaced all spark plugs and wires
- Ran a compression test:
Passenger side: 150 (all three cylinders)
Drivers side: 120 (all three cylinders)
I'm a computer geek by trade so I've reached the end of the things that I know to check (and probably have done some unnecessary checks/repairs).
Does anyone have any idea of where to go from here?
