Joe400
- Aug 21, 2007
I seafoam my truck (93 ranger 4.0) regularly about once every 5k miles or so. The last time, last week, I sucked it through the brake booster vac. line like I usually do, but I probably poured it in faster than usual. It ran rough like it usually does, and I shut it off and let it sit for a half hour. After I started it up, it did it's usually smoke-like-a-chimmney routine and I noticed the idle was still very rough.
Since then, the rough idle has improved slightly, but it fluctuates very quickly between 950 and 700 rpm. It sounds like it is misfiring on a cylinder or two every now and then.
The biggest problem, is when I am cruising about 30 mph, the engine bucks and jerks the truck back and forth, seemingly misfiring.
I pulled the plugs, they look fine (and are relatively new), I ran 2 tanks of injector cleaner through it, I checked for vac. leaks, and cleaned out the IAC and MAF sensors.
The truck has tons of power, it just runs rough at idle and bucks when at speed and under very little load.
Any suggestions??
Any suggestions??
