The truck idles ok for a few minutes if you just pat the gas lightly it will rev but if you give it much it either stalls or starts backfiring through the intake. I’ve replaced the fuel filter and the truck supposedly has new plugs and wires. I haven’t found any vacuum leaks and the MAF has a little crud but doesn’t look too bad. Previous owner did some funky things with the wiring to the fuel pump could that possibly be the cause? I also noticed there is a broken tube that goes from the exhaust manifold to below the air filter box and I have no idea what purpose it served. Thanks for any advice in advance!
