JTH1972
Ok, so here's the story...
Around a week ago, I changed the plugs on the truck. It ran good with no noticeable problems. Around last Thursday, I changed the plug wires, cap, and rotor, and pressure washed off the motor to get rid of all the built up oil on it. The first thing I noticed was that the truck would run decent in a high idle, but the motor would start to shake and sound like it's missing at a lower idle for around 20 seconds, almost stalling, then reving back up into a higher idle.
While driving it, the truck didn't seem to have as much pep as it usually did, and it would really bottom out and start to sputter when going up hills, until it got into a higher RPM range, It would do the same thing on flats on occasion too. This lasted for a couple of days. Fuel consumption to me seemed to be higher. However while driving the truck yesterday, everything seemed to be as right as rain. Fuel consumption is still questionable, but I am still learning the truck.
I thought that maybe I got something too wet when I pressure washed it, but I would assume that it would be running like crap all the time instead of just occasionally? Could i have created a vacuum leak by blasting off oil that has sealed something before?
Any ideas would be appreciated.
