kshen66
I am trying to dig up the past. I know a long time back (probably 2 years ago I read a article about using 2.9 heads on a 2.8. I know the valve arrangement is different and the cam will spin the same direction as the crank unlike the 2.8. I know I will need to have a cam made, and I have somebody that can make me a adapter to run my 604cfm holley 2bbl on the 2.9 lower intake. I already am running the duraspark dist and MSD coil and ignition box. So my question is did anybody out there do this swap or was it just theory. My questions I am wondering are since I am already running a 2.9 crank in my 2.8. I know I had to have the snout of the crank machined down. I cant remember if that was so the 2.8 gear would work on the 2.9 crank or just so the crank would fit the seal in the front cover. I am thinking I can use the 2.9 timing gears and chain, put would prefer to keep it gear to gear like the 2.8. I am thinking if I tell comp cams what i am planning on doing the can gring the cam so if it is spinning the opposite direction than normal it will have the duration I want. I guess my question is does anybody know if there is any work that needs done as far as water passages are concerned. I seem to rember something about needing to drill the heads for water flow? Please dont reply back if you are just going to suggest running a 4.0 or small block. I have been down that road before. I am running the 2.8 so I can stay in the class I am in. Swapping to a bigger engine is not a option for me. This motor is balanced and stroked I just need to get better air flow thru it and the 2.8 heads dont have it.
