rpm
noel
hi i got an 01 ranger just bought it is all stock ?? has 3.0 5 speed auto 373 gears ?? stock size tires 2wd the rpm seems hi to me
what rpm are you guys getting on hiway in od
thx noel
Stock tires for 2WD should be 225/70 x 15 which has a 27.4" diameter
In OD(5th) ratio .75
3.73 axle
At 65mph
RPMs would be 2,230
In 4th ratio 1.00
At 65mph
RPMs would be 2,970
Check that the tire size is correct
And look here to get axle ratio from door tag: http://www.therangerstation.com/tech_library/axle_codes.shtml
