jimsea
- Oct 20, 2007
- Age
- 90
- Automatic
Have a 2003 ranger 4wd ext cab 40 engine and the governor kicks in @3000
Rpm when in neutral, is this correct or should it be higher?
It does run fine and will get up to almost 6000 rpm in 2nd gear on a hill
Ok I found the answer, it is called a rev limiter and is set at 3000rpm
In neutral and park. Could not find the reason for it, I assume
It is to protect the transmission, so you can't drop it in drive
At a high rpm, does this sound right? Anybody know when this
Started?
Started?
