RPM drop and flutter when slowing down
damsie101
My '95 4.0L has had this problem intermittently for the past 2 years. When coasting to a stop or between downshifting to turn, the RPMs drop suddenly to below 500 and flutter between 500 and 1000 a couple times. Sometimes it just drops and stalls, quick enough that it will stall in the time between shifting from third to second. It only happens once the engine is warm and the weather is cold or cool and wet. This rarely happens during the summer months. I replaced the IAC valve last spring and the problem went away, but so did the cold weather. My mechanic replaced the PCV valve at the end of last winter, trying to source out the problem. It did little for the stalling problem, only improved the high idling that was going on. He thought its a vacuum problem.
Anyone else had this problem?
