pxbacher
94 Ranger XLT V6 4.0 OHV - 223k miles and on its 2nd set of heads
Did the valve cover gaskets last weekend and all seemed fine til driving home from work Tuesday. Just after driving up a short hill, the truck felt rough and sluggish, barely making it over the next hill in the same gear. At idle it runs real rough, and turning the engine over with the coil pack disconnected I get a 1-2-3-4-5-fuh instead of a solid 6-count. Bad news.
So cut to the chase - #4 measures 0 PSI. Before I go tearing into this thing again, any ideas if this could be anything OTHER than a stuck valve? Can a broken spring drop it to zero? Seems like a stuck valve is the most likely, and since I just did the cover gaskets, seems like it's thanks to something I did
Thoughts on this (or how I might have fouled it up) are welcome (sort of).
Thanks
-Pete
Thanks
-Pete
