I had even went as far as checking the voltage's at my inlet temp sensor and MAF when running rough and smooth and it all checked out. Makes no sense as to what the hell is wrong.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I know. It's driving me crazy. I just checked the vacuum with a gauge and it is steady at 22 which is normal. I thought maybe a clogged cat. but the vacuum was steady during acceleration all in normal range. I'm going to get the temp. before and after the cat with an infrared thermometer and see if there's a difference. I know that would be an expensive fix but at this point it would be worth it to get this headache over with.I had even went as far as checking the voltage's at my inlet temp sensor and MAF when running rough and smooth and it all checked out. Makes no sense as to what the hell is wrong.
Log inRegister
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.![]()
Engine sputter/Shake/Stall
I cannot figure out this sputter/stall issue. My truck is a 1997 Ford Ranger 2.3L Manual Transmission with l97,000 miles.
Here is the problem:
1. When I start the truck and begin driving and come to a stop sign, the engine will begin to sputter at the end of deceleration. If I sit at the stop, it will work itself out and run smooth after about 10 seconds. (Only happens during the first 2 minutes of driving then the problem goes away.)
2. When I start up the truck and begin driving and come to a stop sign quickly, the engine will stall out at the end of deceleration. If I try to start it back up, it won´t turn over until about 10 seconds later. Then it runs kind of rough then smooths out again.(Only happens during the first 2 minutes of driving then the problem goes away.)
3. When I start up the truck and begin driving and push in the clutch and coast then come to a stop sign quickly, the engine will stall out. If I try to start it back up, it won´t turn over until about 10 seconds later. Then it runs kind of rough then smooths out again.(Only happens during the first 2 minutes of driving then the problem goes away.)
4. When I start up the truck and just let it idle in place, it runs smooth, but when I accelerate it, it begins to sputter at the end of the deceleration. The higher the deceleration the more likely it will stall out. Then I wait 10 seconds and start it back up to find it running rough for another 10 seconds and then its smooth again.
(Note: Engine is less likely to sputter and stall if I use engine braking by down shifting and using the foot brake just at the very edge of the stop.)
What I have done to try and fix this:
1. Replaced Coil Packs, Spark Plugs, and Spark Plug Wires
2. Replaced Fuel Filter
3. Replaced entire EGR system
4. Replaced Throttle Position Sensor
5. Replace Idle Air Control Valve
6. Replace cracked EVAP hose to Canister
7. Replaced Engine Coolant Temp Sensor
8. Cleaned MAF
9. Cleaned Intake Air Temp. Sensor
10. Cleaned Throttle Body
CEL code prompts if I decelerate fast enough to have it stall:
Throws a cylinder 2 or 3 misfire.
Something about driving seems to help it. Does anyone have any idea what this may be caused by?
Sooo...I have two 97 2.3 trucks with this issue....anyone figure it out yet? One has 250K and one had 320K.....If I stay under 40% throttle until the engine gets up to temp it doesn't happen. Both have done it for 100K+ miles now.
If it stalls while throwing its throwing a fit then it becomes a real bear to restart. it will gallop like its got a dead hole or two while cranking.
The most plausible theory I have heard so far is that the valves wear and recess into the head, or machine shops cut the valve seats too far into the head, which recesses the valves, and in turn they become too long and are held open when they shouldn't be under high oil pressure conditions. I haven't verified that on my engine but have struggled with the same problem for about 10 years... I did have the head gone through and the problem started happening about that same time.
Some ideas that might fix it:
- run thinner oil - didn't help one bit for me and how thin is too thin for these engines, really?
- have the valves machined shorter
- find a different head
- have new valve seats installed to correct the issue
- swap to anti-pump-up lifters, allegedly this helps - https://www.speedwaymotors.com/High-Performance-2-3-Ford-Hydraulic-Lifters,7485.html
I chased this stupid problem and threw a TON of parts at it. Always seems like the next thing is going to solve it. Fueling issues, dead TPS, bad EGR valve, leaking injectors, weak coil... etc. On mine it just keeps getting progressively worse and I'm assuming that is because the valves are slowly wearing into the seats. It runs well enough to haul trash once in a while so I may never try to fix it.
That's why I want to try it with the engine stone cold to see its effect (its been 15-30*F here lately)I've had three of these trucks and they all did it - my '88, a 94 and a 96. All same symptoms.
I think it's valve related because on the hard starts that you mentioned, it sounds way different when cranking - it's got that "broken timing belt fast crank" sound like it has no compression. In my case it would usually come out of it faster if I just cranked and held the throttle wide open.
Just wondering if in your case, the key cycle delay is enough time for the oil pressure at the lifters to bleed off and thus it just seems like a fuel issue when it's really a coincidence?
