Rough Country Springs ??
Larry's shee
Almost new (10 miles) set of leveling springs on CL fo $55. Good deal? Anything I need to know about them or installing them. Poster claims his suspension was to jacked to align properly. Will I need new camber bushings, and if I do is this something that is easily installed or should I have the alignment shop put them in? 94 4L 4x4 ext cab Just put new to me Exploder 4leafs on so the factory rake has returned. :icon_welder: :icon_cheers:
I have them from Rough Country....I netted 2.5" of lift. I was out 4 degrees camber on driver side and 3.2 degrees passenger side. You will need camber bushings. Napa sells some adj. one that go to 5 degrees.
