rough country lift question
KWAD RCR
central Cali
Was installing my 4 inch rough country lift yesterday and got to the point where I just needed to put springs and shocks in. The website or instructions never said anything about needing longer brake line for this lift but it appears that the stock lines are not long enough. Anyone have any experience on this lift? Are the stock lines long enough? Do I just need to jack up the arms to get the caliper back in place and the weight of the truck conpress it enough not to worry about it? If I need longer lines can I get them at a Kragen, Autozone, Pep Boys type of place? Thanks in advance
If the shocks dont stop down travel before you run out of
brake line, you definately need longer brake lines.
Look in the tech library for the part numbers for the two piece extended lines.
i just relocated the brake lines so they had more room to travel
Exactly, only snagged 1 brake line with mine from Jyard, built a drop bracket for the other side, dropped 3 " ,.........
