Rolled my truck
njdriver02
2.3 EcoBoost
last night i rolled my truck, planning to pickup a donor truck and swap the cabs, i think the damage is only to the roof and busted tire, don't know for sure because i had to go to the hospital for stitches.
i can just swap the cabs right?
yes, helps if it is the same year too. and you will wanna take it to a frame shop to make sure your frame isn't tweaked. go over the whole truck with a fine tooth comb. put it on a lift and make sure that all the bolts, mounts, and brackets are not f^&*ed up. and your wheels/hubs are prolly messed up, but maybe you got off lucky depends what speed you were goin and how many times you rolled for what damage to expect. Glad you are ok though and hope everything works out.
yeah i am going to pick up a donor truck, fix the cosmetic and then go through everything else, does the entire interior need to be gutted? i am assuming so.
I have a 94 cab if you want to pull it off my parts truck... Have no idea if you are even in my state though, but itd be cheap!
5 stitches in my elbow that is about it,
what color is the cab, i need a white on. Harry you pull it in hazleton has them for $75 but you have to haul them out, two guys it will be tough.
welcome to the club.
thanks, i actually saw the truck yesterday, i feel even more fortunate to walkaway, pulled the plugs, cranked it, spit all the oil out, put the plugs back in, added oil, and she is running again, tire came off the bead, reinflated it, and itsa good.
now looking for a donor truck i need, driver door, window
windshield
rear window
cab
mirror.
maybe hood front quarter panel
How the hell did you roll it? I dont know if i would put the time and money into a 2wd 4 cyl. JMHO
Yeah, TBQH, you can probably find another one for cheap... well, hell, you could probably buy a whole 'nother one and use it for a parts truck then.
