- Jul 13, 2013
- Salida CA
- Automatic
Started with some 2" 1/4 wall square tubing, and 1 3/4" 3/16 wall round tubing.. Put a slight bend to the tubing, placed it against the square tubing marked at cut straight.
Cut the 2" square tubing at 45 degrees on both ends on the band saw. 49 1/2" worked best for distance between tires for me.
Cut 1/4" plate to fit inside the 2" square tubing and welded in place, and then grounded smooth.
Welded round tubing to the square tubing.
Places on jack stands, measured to frame and cut 2" square tubing for frame mounts. (Unseen)
Need to paint before attaching to frame.
All in all not to bad of a build..
