roadhog2002
roadhog2002
I have a 2001 ford ranger XLT 4.0ltr 4x4 and I am having two problems and I am not sure if they are related. 1) Is at idle if I turn on either the heat or AC i get a slight drop in idle. I have removed the IAC and it looks clean (but i can't find anywhere that tells me if when disconnected it should be open or closed, it looks closed) I tried unplugging the IAC while running and the truck stalls immediately.
2) if I turn on the AC the compressor cycles 1-2 sec on and the 6-8 secs off continuously and does not get cold, i have tried twice to add 134-a refrigerant and doesn't really seem to take any. I only have a hose with a single gauge and the pressure goes between 90 and 100 lbs but nothing changes
