Rim Cross reference
Madracingalley
Gansevoort, NY
I'll make this brief cause I just wrote a whole thing on this and the computer made me sign in again and all the work was lost.....
this is going to be a Rim Cross-Reference for ford rangers.
Please use Factory rims ...NO AFTERMARKET RIMS....
heres an idea...http://http://www.mgexperience.net/article/wheel-xref.html
Include-------------------------------------------------------------------
What rangers the rims will fit:
Maker of rim:
Model of car the rim is avalible on:
Years the rim was used:
Picture of the Rim:(VERY HELPFUL)
Modifications Needed:(if any)
Any Comments:
(repeat if necessary)
This is going to hopefully be in the Tech. library someday
Thank you for helping. You will be cited
Cheers:icon_cheers:
Any RBV rim should fit any other RBV, the only limiting factor would be if you had a 98+ rim with a small center hole and tried to put it on a 83-97 truck 4x4 with hubs.
well then, I guess that I'll set it up for.
Heres an example. It may not actually work
Maker of rim:(Ex-Jeep)
Model of car the rim is avalible on:(Ex. Grand Cherokee)
Years the rim was used:(Ex.99-02)
Rim Cross reference
Modifications Needed:(Ex.none)
This will show up as
Jeep, Grand Cherokee, 99-02
Rim Cross reference
No modifications needed
