dunoon
- Feb 1, 2008
- Age
- 79
Got an '84 2K that I use around my farm and to run errands. Had to replace the head (crack) and the cam (flat). I removed all the emission BS and plugged all the unecessary vacuum ports. It runs real rich like the choke is nearly closed, and smokes some. I added a air bleed to the intake but, didnt make much of a difference. As there is no main jet needle valve to adjust, I'm stuck. Does anyone know of a carb from something else that would work without a lot of modification or is there something that I can do to this carb to make it run better.
Thanks
Thanks
