- Aug 6, 2007
- Age
- 37
- Plattsburgh, NY
1999
i just got done putting a 6inch lift in my explorer. i did 4inch coils up front with 7 washers under each coil. its the max you can go.. its bout about an inch of rake but its just about where i want it.. the ttb brackets i copied the ones on my ranger an built them so i have them in the bottom holes which are for 6inch .. when i had 4inch brackets in with 2 washers under the coils i had really bad positive camber.. well now after adding 7 washers an building some longer ttb brackets when you go in reverse you will have negative camber an when you pull forward it straighten back to where its supposed to be an you have a SLIGHT positive camber .. i DONT however have a drop pitman arm on at the moment.. would this cause this issue with the camber? with my black truck i had to run the 4inch ttb holes with the 6inch coils.. wounder if iam going to have to do this as well? i just ordered a drop arm an received it today so tomorrow iam hoping to get it on an get it aligned by noon...
what do you fellas think would cause this issue? ball joints are BRAND NEW tie rod ends are all good
