AgPete139
09/2014 OTOTM Winner
⭐Supporting Member
- Aug 12, 2007
- Houston, TX
- 4.0L
- Manual
- Total Lift
- ~9"
- Tire Size
- 35"x12.50"x17"
I'm now running 24 lb. injectors, with 1.7 Cobra Rockers and an Explorer intake. I usually get 270-290 miles out of a tank with normal driving - this is including the occasional run in's with the Ricers. But if I watch myself, I have gotten 340-370 miles (mostly freeway though). It's very hard because I've always got some fruit cake punk wanting his doors blown off. Anyway....... I actually read about this method in a magazine (Super Ford or MM&FF) some time ago. There were some guys who were battling to see who could get the best mpg's out of their hopped up rides. I remember one of them being a Fairmont. I tried it, and it worked.
Interesting. Staying off the gas and pretending there's an egg under it is one mental mindset I try to use for better MPG's. I like reading articles, and MM&FF is great. Do you have a scanned pic or an online article to the one you read? (It's prolly no different than every other article, though.)
What gears are you running?
Stock, whichever that is. I forget, but IIRC it was 3.27. I looked at it a couple years back out of curiosity, and promptly forget. My two 4.0 Rangers, on the other hand, have had 3.08 to 4.10, and 3.55 to 4.88. Now you've got me curious, and I'm gonna recheck & commit to memory. I think it's also do for a limited slip rebuild and gear oil change @ 100K.
I run a mass air adjuster too, which helps fine tune. Forgot about this.
http://www.mass-air.com/Products.htm#Air Adjuster!!
Interesting. Reading more up on this...but still, I wouldn't want my 5.0 to run lean for extended periods of time, especially with my timing advanced. What is your timing set at?
I've mentioned this before, but it finally looks like the trans is coming out next week. My friend is going to build it for me since it's sitting at his shop anyway. I'm going to have him pop a new rear seal in it while it's apart because it leaks like an SOB. The best part, I asked him how much and he said "don't worry about it". At first he told me all I had to do was buy the parts. So in the past 2 years my girls got new heads, new paint, and a soon to be new T5 (and a new LUK clutch if my King Cobra is worn too much).
BTW, do any of you have any experience with a LUK clutch in a Mustang? I've had the stock, a Perfection Hy-Test (they also make Zoom), and this FMS King Cobra. The King Cobra is BY FAR the best clutch I've ever had. The Perfection Hy-Test was a big POS and the disc actually busted all to hell on me once when I down shifted.
Awesome. I rebuilt the tranny in my 1970 Porsche with a friend for free, and he showed me a couple ways to refinish certain parts. Like the dog teeth & synchros...some couple be flipped around, 5th could be switched & flipped with 1st (since there is 0 wear on the backside of the 5th), etc.
King is a really good clutch, and I've also had the stock from Ford, and the FRPP clutch (which is good & grabby, but not as smooth for DD, IMO).
