g356spd
Guest
The M5OD in my B4000 is ruined and i picked up an HD trans to swap in. I am going to replace the slave cylinder while im in there as i believe it is shot and making noise. Do i need to replace anything other than the slave itself like the tubes that run into the trans? Is OEM the best slave out? Any thing else that i would need?
I also want to replace the rear main seal as its leaking pretty heavily. Is that just a pop in circular seal?
