militarydave
well i tried selling the truck without replacing the pump again myself..... no luck. the low-ball offers i got weren't even worth the new tires that are on it.
i finished reading the other fuel-pump related issue post(s) and determined this:
My Fuel Pressure Regulator is fine. (the truck starts, fires up, idle's no problem)
Relays are new/tested/they work
I doubt the Inertia Swtich has been touched/kicked, but i'll double check (its in the Chilton's manual right?)
Electrical connections are fine....
and has a new fuel filter.
So, my question (to all) is - a little bird told me if you run your gas-tank too low (on empty basically), it can damage the pump? is this correct?
secondly, the new fuel pump i bought only had a 1 year warranty, so $96.57 later.... i'm the happy owner of another fuel pump with 1 year warranty.
now i recall dropping the tank is a PITA
but a buddy of mine actually took off the truck bed and replaced it that way?
only 4 bolts holds the bed.... but is that easier to do or just crawl underneath, jackstand the truck and drop the tank (again) in the garage?
any tips are greatly appreciated!
-dave
-dave
