Red beast
- Mar 11, 2013
I have searched and i cant seem to find the info im looking for. Mixed reviews on being a real bitch or easy. I got the part, popped the hood and took a peek. My question is how the **** do i get to it? Im fairly confident on putting the synchro in but how much do i need to unbolt to get to it? There is no way that this is as easy as i have heard. I can barely even see it let alone check the orientation of the way its positioned. Are there any writeups to do the full replacement that have more than just how to orientate the gear? Do i take the upper intake or lower or both off? I can see the coil pack some of the harness and the intake being in the way. Also i bought the tool to set the gear degrees. This parts looks like a drop in. Do i really need to mess with all the tdc and rotating the engine ten times? I have heard to pull the sensor put the tool in and have a buddy spin the engine till the tool drops completely in place. Is that all? Or is that wrong? I really need to change this piece and i am looking for all the help i can get. Im on a tight timeschedule with work and there is no way i can leave it at a shop. Even if i have to do it at night after work i will. Just looking for the right info to get the job done. Thank you for any help.
