dssranger
- Nov 28, 2009
I need to replace the fuel pump relay connector as well as the EEC Power relay connector, they are both severly corroded. I have been able to find a fuel pump relay connector at the parts store, but not the EEC relay connector. The actual relays are different but the connectors are the same. Except I noticed the Brown socket is wired with 12 GA wire and the Green is wired with 14 GA wire. So, if the brown socket with 12 GA is the fuel relay connector I am thinking of getting 2 and wiring it into the EEC relay, I would have to cross match wire colors, since I cannot find a direct replacement, the only other solution might be to find spade connectors. Long story short, has anyone purchased a EEC relay connector? I have checked Autoaone, Oreilly, NAPA, Ford might have one, but it is considered obsolete.
