replacing pipe from cat to muffler help please
91rangerstx
Michigan
where can i get a new pipe from the cat to the muffler in a 2.25 size instead of the 2in and if anyone has there exhaust system with it exiting in front of there rear tire i have to short that same pipe too right?? to be able to move the muffler back so i can angle out. Also by me change the size to 2.25 from 2in is my stock cat still going to fit. Any info would be great please !!!!!!
any exhaust shop should be able to help you, they can flare the pipe from 2 inches to 2 1/4 or 2 1/2 depending on what you want, then run that pipe to your muffler. for a side dump id have the muffler placed where the frame kind of comes up (halfway below the cab and bed) and then run your tip out the side from the outlet. thats the way mine was done at first, then the cat was changed out w/ an aftermarket cat that was shorter and moved the muffler under the cab and changed the exhaust angle out the side in front of the tire. hope that helps.
