lucasbryan
- Mar 20, 2010
- Automatic
I replaced the front shocks on my 03 Ranger Edge 4x2 today. I have read different articles about the torque specifications and wanted to make sure I was ok. The Haynes manual said the bottom two bolts should be between 15 and 21 ft lbs. The top stud should be between 30 and 41 ft lbs. I have also read that if the bushing sticks out about 1mm from the washer it is good to go. I am 75% confident I am between the torque ranges but wanted to get some advice whether or not it would be an issue if I wasnt in between those specified ranges. Or does it matter? I also read just to get them as tight as you can. Thoughts?
Thanks,
Thanks,
