replacing front main seal
badazz66gto
Was wondering if anyone had any info on how to get the crankshaft gear off so I can replace the front seal.
Thanks Keith
Few light taps with a plastic mallet? I don't remember having any difficulty at all getting those off in the past, the bolt and large washer should be what holds it in place. I'm almost sure I did not need a puller or similar. Sounds like a stuck key/keyway inside the gear.
Use a puller...
I had some issues on 1 block I had purchased recently. What it looked to me as if they painted the block and got some extra pain on the crank and then put the gear on.
