BRlippincott
replacing dead transmission
Hi, I am new to this forum. Mostly I'm looking for the best data to get my truck back on the road.
I have a 1994 Ranger XLT, regular cab, long bed, 4wd. It has a 4.0 under the hood, 80K miles, and .373 final drive with limited slip. I believe the tranny is an M5OD-R1, as per the tranny info page at this link:
http://www.therangerstation.com/tech_library/ManualTransmission.html
The truck broke down on a highway trip from Austin to San Antonio, and turned out to be a seized-up (really fried) transmission input shaft bearing due to low tranny fluid. The heat from said failure melted the plastic clutch slave cylinder housing. The tranny leak was worse than I thought, it would seem, as the tranny fluid I check regularly was a bit below half before I removed it from the truck.
Looking for a replacement let me to Wrench-A-Part where I was able to locate and extract a healthy tranny from a 1999 Ranger 4x2 with a 3.0 V6. Not ideal exactly, but the online reading and other research I did said it could work. I am willing to cope with the lower three gears being softer. It appears the tail cone can be replaced with my 4x4-to-transfer case section and some seals replaced. My questions are:
1. Can I swap the fork & shift assembly cover from my old trans over to the replacement?
2. The 4x2 shift cover does not have the switch opposite the back up switch, the boss is undrilled. Can I bypass the other switch, which I believe is a neutral safety switch relating to the 4WH to 4WL shift function?
3. are there any other major concerns with using this tranny in my truck?
I plan to get some pics of what I have posted in the next day or so.
I am on a timeline for a trip to west Texas in May, and I will be pulling a small trailer less than 1000 lbs. This truck has made the trip twice before and is capable. Thank you in advance for any help anyone can offer to getting this done so it will last.
