replacement engine
van o
panama IL
What all would be involved in putting a 97 3.0 dis ranger engine with automatic transmission in a 93 3.0 distributor style engine with a 5 speed?
some have said that it is easier if you keep all the components from the older motor ie: swap intakes so that you dont have cut any wiring.
So if I swap intakes I can put a distributor in the 97 engine?
