Replacement beam brackets
kevinbmx77
Does anybody know where i can get a set of replacment i-beam brackets? I need a set for my truck and i want them to be a stock height replacment, i can not for the life of me find an oem style set
Sent from my SM-G920P using Tapatalk
#2 on this chart, anybody know where i can find it for sale?
Good luck. I can't think of anywhere that would have them. You're best bet is to get some at a wrecking yard or from someone on here that removed theirs to install a lift kit.
I might have some in my junk pile.
I know the passenger side just unbolts so i can get that at the junkyard easily, the drivers side im not so sure about, if you do have the drivers side bracket i could really use it. Im not to sure how the driver's side actually bolted up though and cant find any actuall pictures
The drivers side bracket, which houses the passenger side beam, is riveted on with 4 rivets. They are kind of a pain to remove, but it shouldn't take more than 30 minutes or so with a grinder and punch.
Here is a pic; this one is a lift bracket and has bolts instead of rivets.
I have a lift on my truck now but its 2wd so im wanting to lower it back down and i think when we put the lift on the drivers the stock bracket had to be cut along with the rivets being broke, not sure if i can undo that, but welding may be my best option for now
