trizzler
- May 5, 2008
- Age
- 44
- Automatic
Hello all, the truck (2000 Ranger, 4WD auto, column shift) began showing the wrong gear when shifting, so I hopped under to check the linkage. It seems that the plastic clip that holds the shifter cable in a bracket and keeps it rigid has broken and no longer allows the cable shift to properly. Can I replace the broken clip without replacing the whole cable? What would it be called? Part number?
Thanks much,
Thanks much,
