How can I drive this around when it only goes about 15mph? None of the roads around here are that low...Could I just drop the tank and drain it that way? Then fill it up and add some HEET to the tank to get rid of the water in the lines?
Probably, I have never needed heet to properly burn regular fuel in winter.
The fuel line freezes up if I run E10 ethonol in my Ranger in the winter though, gotta dump some heet in it to keep it running long enough to correct my error and get some straight gas in it.
Maybe you got some fouled plugs?
WHY do you think you have a bunch of water in your tank and lines??
Your first post and your second post( this one ) gives no clue of your assumptions of water problems.
Is it that because you added a tiny bottle of heet and you THINK your truck runs a LITTLE BETTER? yet in this post you say it only accelerates up to to 15 mph, I aint trying to be a dick but WHY do you THINK you have this terrible water issue? maybe if you tell us, people can help more.
You know that truck of yours is a big WOPPING 21 YEARS OLD!!!!!!!!!!!!!!!
Could it just be a kawinkie dink that when you filled up your tank that it just started having an issue after alllllllllllllll these years? I am just saying
At startup, the truck idles fine. Then, after a minute or two, it starts acting erratic. This happens once you start giving it some gas. It will let me rev it up to about 2000RPM, sometimes as high as 3500RPM, but then it stops going any higher no matter how much gas your giving it. Once you let go of the gas, it drops below 400RPM, stumbles, sometimes recovers itself and other times it will simply die. When it recovers, it will do the same thing when you apply some gas.
+1 check your plugs and plug wires, it sounds like your plugs are fouled.
MAP sensor...usually located on the firewall passenger side...if it's not a water/fuel issue then try swapping out that sensor with one from the junkyard (new cost about $200)...other than that...I did post information on how to remove water from the tank and test it...if that doesn't help and your plugs are clean then it could be a sensor issue...my Tempo did similar things...and between the inertia switch and the MAP sensor I managed to get it working properly and drive it till almost 400,000 km before the clutch went on it...
OK, where could I get the paste besides the boating supply store? Don't really have one that close around here. It sounds like a great idea to me.
