Removing speedometer assembly.
gertsdsbs
On the Moon
I'm trying to replace the bulbs behind the speedometer but i cannot remove the whole thing. Anybody know how to remove it. Its an 1986 ford ranger 4wd 2.9 v6. Thanks
Did you get the cluster out of the Dash?
pull out the ash tray pop off the peice of trim thats on the right at left of the ash tray pull the piece of trim by the light switch pull out the light switch knob (u have to reach in the back of the switch feel for a little butten on the back of the switch and pull the knob out, take out all the screws on the dash trim and that should pull out then the 4 screws on the dash and if u lay on your back and reach up fallow the spedo cable u can see were it attaches to the cluster u can push a little tab while pulling out on the cable u can remove the spedo cable from that then the cluster should pull out far enough to unplug the wireing.
