removing body lift 94 ranger
Young_unn
Cleveland Ohio
i have a 94 with a 3 inch body lift, what does it take to remove this lift?
the front body mounts are completely gone, plus i want the better ride of less lift.
i still have the suspension lift, and im thinking over 10 inch of clearance above my 235/75/r15's is a little much
There's probably a front bumper bracket that needs to be removed
Probably need to remove a steering extension and perhaps a shift extension if it's manual
There should be extension brackets on the cooling fan that will need to be removed
There's probably also an extension on the radiator lines and engine ground, but there shouldn't really be a need to shorten them
Other than that, it's removing the cab/bed bolts and removing the blocks (you'll need to get shorter bolts)
Also check out http://www.off-roadweb.com/tech/0503or_removing_truck_lift/index.html
I isnt going to ride any better without the body lift, unless your talking about a higher center of gravity and the tendecy to roll.
