preflight
Ok here we go lol its 40* outside , I have all the bolts out ,
some things I have learned along the way with my 93 ranger .
1) If the plastic sleve on your slave cylinder will not work ., remove the master slave cylinder and hydrolic clutch from the fire wall and fish the whole thing line and all back down to the bottom of the truck (hint ) there might be about 2ft of plastic tube between the frame and body just jack the body up till you can pull and free the line ). (2) the top bolt`s is not too bad you need a ratchet where you can put different angles on it put the ratchet on the bolt from the top and loosen the bolt from the bottom the bolt on the passenger side is easy.
(3) the bolt on the shifter loosen and remove and place on the back of threaded by the seat tighten till you can pull up on the shifter to remove it ..
,but if that dont work then lift that rubber pice up and undo the three screws
star head and lift the whole thing up and off.
that is what I have found so far. I`m going for the drop tomorrow
I have lost the daylight
GREG
GREG
