remote start
509lifted
Firefighter
chelan washington
ok so i have the acc wire hooked up and constant but the 92 ignition wiring diagram says that they are other colors so i am having trouble locating the startedwire in the ignition they say its red with light blue but i dont even have a red and light blue any help would be appreciated TIA
Figure out what voltage it is suppose to be and go from there. A starter has 3 wire, ground, 12V constant (hooked to the battery) and your ignition wire (12V trigger for the starter).
its my new 92 that i got about two weeks ago and i used that diagram and all the wires that are on my harness are different
use a digital multimeter or a test light and check each heavy gauge wire in the ignition harness as u crank it with the key switch. it'll only have voltage when its trying to crank. once u find it, if u are also installing a starter interupt relay, cut it into then try again to crank it. if it's the right one it won't crank.
yes i have and it doesnt show the wires that i am working with like the constant is white with blue stripe instead of yellow and the acc is red instead of grey and yellow
