2.3L ('83-'97) Relearn Procedure
Tenmile
OR - USA
Vehicle
Drive
What is the best/propper relearn procedure after changing the IAC (Manuell Transmission)?
Drive it for a couple of days. The computer constantly relearns and makes adjustments. When you make a change, you just have to wait on it and go through several drive cycles.
If you want to start completely over, pull the battery cable off for a minute or two, and then hook it back up and drive it for a couple of days. It will have to relearn many different things when you pull the battery cable off.
That's what I'll do today. I had the Batterycables all night jumped. The Comp should be clear now ......
Event Coverage
TRS Merch
