Yep, we'll have plenty of time. Heck, I might even have the Lj's motor rebuilt by then.
Sunday we got alot accomplished. We got the Dana 35 in, we used the complete assembly, but used the ranger coils, and retained the spacers.
I also cut the buckets, and installed some F250 shock mounts which were a freebie from a friend. I used two of the original bolts from the f250, with the front lower hole lining up with the rivet hole that's left from cutting the old shockmount out. The upper back hole was the other, which lines up with a slotted hole in the frame. This allows a little angle adjustment before welding it in. I testfit the shock, and got to welding. I stitch welded the bottom and rear side to the frame, and the front side to the tower, and also plug welded the two remaining bolt holes I left the corners and top unwelded, so I wouldn't have a completely heat affected patch to tear off.
They turned out pretty good I think, should be plenty strong.
For the rear, we ended up with the '99 (iirc) 7.5 from work, it was thought to have a bent housing, but turns out it's not, I welded up the spider and sidegears, and we slapped it in, bolting it up to the explorer leafs, minus the overloads. This was basically needed because the d35 was 3.73, and the old set was 3.45.
I also started mocking up the 3/4 ellip setup, I got the old shackle hangers off, and started playing around with placement and materials for the halfleaf mounts. I basically have to be very careful with the placement so there isn't any unexpected tire rub.
One thing I've been toying with, since I can design the ride height into the 3/4 setup, I have the option of ditching the factory blocks. Axlewrap is not a concern, because I will have an antiwrap bar. So what do you guys think? Aside from having one more part to break (anybody broke a factory block?
) I don't see any reason to take them out, if I do, I've got to get u-bolts, which means less
So what I've got left is to make some halfleaf mounts, cut the halfleafs out of some suburban front packs, which are two leafs with military wrap. These will be direct replacements for my 1/4 elliptical springs, so we can carry a universal trail spare, and also can play around with spring rates between the two.
I need to cut down the front driveshaft, but that won't take long, and weld up the autohubs, or find a better way to make drive slugs. Then it's on to the flatbed and exo. The new(er) fenders off the donor truck will be going on, only after gratuitous plasma massaging.
