adsm08
Senior Master Grease Monkey
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
OK, this might be a question best directed at the farming types, but I'll take anybody's input here.
Two years ago I painted the truck, it was admittedly a quick and dirty el-cheapo job. I used Valspar Tractor paint because it was cheap and I was more interested in getting the truck the color I wanted than doing a permanent paint job.
Over the last two years I have had to strip back sections of the paint for various reasons, like making repairs to the metal, or fixing poor adhesion, assuming from improper surface prep. I keep finding this rust-red substance under the paint, usually between the metal and primer. It is the right color for rust, but I am thinking it isn't actually rust for a few reasons...
1) It is a very uniform coat, but it doesn't cover the whole truck.
2) I am finding it in areas where there was no rust before I painted, and not finding it in some areas that I had to treat.
3) It doesn't react to any of the various rust converters I have. If I use the phosphoric or tannic acids it doesn't turn black. If I use evaporust or similar is doesn't bubble, and if I use naval jelly (not the same as naval jam) it doesn't stink or turn colors (every other time I used it on known rust it started making funny smells and turned a yellow/pinkinsh color).
My most recent encounter with this stuff is stripping the roof again because it was bubbled and peeling. What I am finding is that the spots that bubbled were over areas that had been badly (not deep, just a large contiguous area) rusted but there is no fresh orange rust, just the black converted iron phosphate. I will admit I forgot to re-sand the roof after the converter was used, which is probably why the paint didn't stick.
Anyway, enough rambling. Does anyone know what this red layer is? Does the Valspar T&I primer turn red after it is applied and painted under?
