holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Total Lift
- 7
- Tire Size
- 33x12.50R15
FIrst off the truck is an 86 with an 88 wiring harness and 90 computer (its a mutt, I know) I have been having an issue with a recurring CM code 18. I have been having issues with the truck hanging at 2500 rpm when the clutch is depressed when shifting. TPS baseline voltage is .841 volts and IAC is functioning correctly. I pulled codes today and I got KOEO 11 with the code 18 CM. And I also got KOER 11. Would a tach circut irregularity cause the running high between shifts, a high idle (1200 RPM), and occasional heavy pinging (base timing set at 10* spout removed)? Would relocating the TFI Module and not extending the shielding cause this problem? What about the IDM resistor?
