Recommendations on a gasket set?
whatelseisleft
2005
I have an 05 B3000 and i have a check engine light on for a miss in cylinder 4, done plugs and wires, did a compression test and it has lower compression than the rest of the cylinders. I have to pull the heads next, I'm thinking/hoping its a bad valve or valve seat. So I was wondering what gasket set manufacturer you guys have used, and what kind of experiences you've had. I have always used fel-pro. But curious as to what else is out there. Also any recommendations on head bolts. Fyi the truck has 108k and was originally a rental vehicle
FelPro or Ford and new Ford head bolts.
pay close attention to the condition of the head when disassembled... if there are any signs of the exhaust valves receding save yourself a headache and do both sides. It would be a shame to fix the problem only to have it reoccur soon afterwards on the other bank. Some may say it's a lot of unnecessary work, but I really hate doing the same job twice.
I use fel-pro gaskets when I had my 3.0 out awhile back. I didn't do a full rebuild but I did replace the following gaskets/seals:
-Oil pan gasket
-Valve cover gaskets/grommets
-Rear main seal
-Upper intake gasket
Aside from a small leak into the bellhousing (which I can't find for the life of me, seems to be motor oil, on the tranny side of the aluminum plate thingy) the engine is dry. The only thing to note is that on the valve covers and oil pan gasket there are two spots which need sealant (I used high-temp orange RTV), which are the transitions between the block and cylinder heads/timing cover. Just a little dab.
-Oil pan gasket
-Rear main seal
Sounds like I've got the same mysterious leak! :D
I had my 3.0 out late last year & did a near total rebuild (pretty much everything except short block). An occasional drop of fluid forms at the very bottom of the bell housing on the back side of the rectangular opening. At first, I thought for sure we damaged the clutch slave cylinder when we put the engine back in. However, the fluid level in the master cylinder hasn't dropped at all & upon closer inspection of the leaking fluid, it appears to be darker than I thought (more like oil). I'm stumped for now, but it'll have to wait till spring..
-Mike
I already planned on doing both heads, I kinda suspect there may be a valve issue.
-Mike
Sounds like it (except I have an automatic).
I do know my valve cover grommets for the PCV and oil cap tube seep/leak but I have yet to find said grommets. As for the leak, no idea...
Ordered my gasket set and head bolts this morning. less than $100 through rock auto.
