2.9 l build expectations
Hey Ace,
I suggest the following:
expect to replace both the crank and cam bearings (very prudent since you don't know what it had been through)
-replace the water pump (prudent, worth doing with the build)
-replace the oil pump and pick up (prudent, I used melling HIperformance but stock replacement is cheaper)
-.030" over bore, pistons, rings and machine work (may or may not be needed, this can get pricey if you aren't dedicated to being frugal; also recommend using the 2.8l flats)
-if not 89T heads, get them or purchase aftermarket ($170 ea. refurbs)
-then just general tune-up stuff, plugs, wires, cap/rotor, oil, hoses and belts as necessary.
So if you do just the "prudent" stuff, I expect you can get out of it with your $150 initial and just about $200 more for a reliable engine (depending on the actual condition of the donor).
