Rebuilding Ranger 4x4 front end
WayOutBack
London, Canada
Hi Everyone
So in this video I go thru replacing a lot of the common components in our Ranger front ends. If you look at the comments section in the video comments you can jump to the component you want to replace.
Lower Ball Joint, Upper Ball Joint, Camber Shims, Sway Bar End Link, Axle Seal, Brakes.
Again if you feel uncomfortable doing this it would be best to take to a mechanic at least by viewing you can figure out what they are doing.
Thanks
Zac
