Rebuild
glenn123
Im thinking about rebuilding my 2.9. Can someone tell me what i will be needing to replace and do the sell kits that have everything in it i need? And how much do the kits cost? And about how much would it cost me to pay a shop to build it if i got everything i needed?
I have been looking into this and for me it makes more sense to buy a remanufactured engine. For me the rebuild seemed like the cost was going to be open-ended. And the cost of the rebuild looked to me about the same as the remain and that was me doing the work.
Oh during my research I spoke to a race shop who wanted $4500 for the rebuild...hahahaha
If you don't already have the tools, or access to the tools, then you shouldn't be messing with it. Buying tools is really what can make or break the rebuild budget. Things like micrometers, telescoping gauges, engine hoist, etc.
You're going to have to measure everything and determine what needs to be replaced. How much is worn out of spec and / or broken determines how much the rebuild will cost. Basically, you have to take the motor apart and inspect it before you buy the kit.
I would advise you to go get yourself a junkyard motor. That way you have spare parts. Usually they're cheap enough, and can save you a good deal of money in the long run with your rebuild.
The other thing to do is find a good automotive machine shop. Compare prices. Also, look around. Is the place clean? How much other stuff is there? Are there any other Ford's there? Talk to the guy. See if he keeps all the valves, rockers, pushrods, etc, in order. Some people don't. See if he media blasts aluminium parts so they pit up, or if he knows enough not to do that.
Although the cost to rebuild can be open-ended, I recommend doing it yourself, if you have the means to do so. That way, you can measure everything yourself, and you can make sure it's all right before it goes back in. I doubt others would be that careful. Also consider that the parts going into a reman motor are probably made by the lowest bidder. Do you really want lowest bidder gaskets in your motor? Bearings? Piston rings?
^^^x2
Richard
i got a long block for about 2K and then just did the swap that way. alot faster i think than doing a rebuild
Shop here will price match on rebuild kits you can find online. What I will do is have them tell me what it needs and have them order the kit with the correct size bearings/pistons (if needed), and an estimate of total cost.
hey if you go to nvtengine.com there rebuild engine is 1300 for ranger
it'll be cheaper to go buy a running 4.0, a new tranny and t-case than it would to rebuild. i was gonna do it to my 2.9, but i decided against it. i just replaced the gaskets and i'm gonna run it until i can get a 4.0
the cheapest kit i found was around $600
would the 4.0 bolt right in?
