s10350
- Mar 15, 2008
- Automatic
I am rebuilding my M5R1 and I'm running into troubles. I follow the service manual assembly instructions to get the bearings and bearing plate installed on the rear of the transmission. Then when I try stand it up on end to install the bearings from the bellhousing side I can't get the input shaft bearing race installed. the input shaft bearing isn't centered in the opening and I can't figure out why. Is there something i'm missing here?
