Darren94
So, i recently picked up a 98 B2500 with 179k on the ticker for $2000 which at the time of purchase seemed good because it run really well and was very clean inside and out. But, after a week or two of reading here and replacing parts trying to cure the rough idle and tendency to bog down while taking off in first (when motor is cold), i did a compression test. The numbers were
First try (cylinder by cylinder, no WOT): 75-87-172-177
Second try with all 4 plugs removed and at WOT: 96-90-215-210
Third try with oil added to the low cylinders: 217-240-215-210
Fourth try less than one min after third try: 122-137-215-210
Through the help of others that replied to my post, it seems to be clear that i need to re-ring it even though it runs really strong minus the the problems above.
My question is: if i decide to re ring it what else should i replace while i have it apart. Also, what to the re-ring kits usually come with??
I am either going to drive it until it dies or go ahead and fix it but, if i fix it i want to do it right. What would you recommend?
