Rebuild or replace?
Spanqwire
Cedar Lake, IN
Ok, so my transmission is pretty much dead. I drive a 94 Ranger 2.3 and its got a 2WD automatic transmission. I've done a fluid/filter change, made sure there were no leaks, put in a bottle of lucas transmission fix and it still doesn't perform like it should. I get 1st and 2nd gear and reverse, but as soon as it tries to shift out of 2nd, the engine revs up to about 5000-6000 RPM like its just in neutral.
My question is, should I just get it rebuilt, or find one in a junkyard that works?
Money is an issue either way, so it's gonna end up being parked for a while, only being started so the engine doesn't seize up. :bawling:
what i would do is find a rebuild kit and then find a transmission in a jy see how much either is gonna cost and go with the cheapest.
Auto trans's out of a bone yard have always worried me. I avoid them at all cost. Where at least with a 5 speed you can check some basics out but with an a/t your lucky to check the valve body. If your mechanically inclined and have a decent tool box you could attempt to rebuild it your self. It will be probably 400 bucks cheaper but will suck up some time
Ive had good luck with my junk yard trans (and rear end), throwing 500+ ft lbs of torque at it. But then again it is a c6 lol
Get a standard. As long as you pull the pedals, flywheel, clutch, hoses and cylinders, you'll be set.
You'll save money in the long run by not having to: add so much fluid, check or change it as often, or lose efficiency by worn down hydraulic systems.
Before you do anything try Aamco and see what is really wrong. It might be a simple band adjustment. It would be worth it to see before you spend money on a rebuild (unless you know how to do a rebuild). A few years back my 89 BII (that I bought new) started doing what yours is doing. It had less then 70,000 miles on it. I had done a trans flush and filter change at Goodyear about a month earlier and I went to Daytona for a week with a buddy with my bike trailer and three vintage dirt bikes. On the way back the trans started to do the slip thing after leaving a traffic light just outside of Daytona. I drove it around town for awhile and it stopped and then it started to slip a bit after I left another traffic light. I saw an Aamco place and pulled in and had them look at it. It cost $75.00 for a quick band adjustment. It never slipped again after that. I had that BII for over 17 years. When I sold it, that trans still shifted like new.
straycat has got it right.
Take it to a shop. I have a privately owned tranny shop in my area that I've literally been going there for decades.
It might be something simple.
I knew someone was gonna suggest the DIY solution... I'm not THAT mechanically inclined nor do I trust myself with it lol... from what I've heard, it would end up being cheaper just to find one in a junkyard, my mom has an 01 Blazer with the same problem and it was cheaper for a used tranny (about 1200 bucks for the job)... I bought this truck like a month ago for 2 grand knowing the tranny was almost done... everything else is perfect on it, and over here, 2 grand is a STEAL for something that runs lol
either way, im gonna have to save up for it... but 3-4 grand total for an 18 year old truck that is in amazing condition doesn't sound bad at all
if it was a 4x4 with a 5 speed , 100k miles and a 4.0 w/ manual hubs i'd agree with you, at least that's how it is around here.
Get a repair book from the parts store that has a chapter on adjusting the transmission.....it's very easy to do with a couple wrenches! It'll only cost for the book. You can always spend $$$$$$ if adjustments don't help...
